Fully automatic washing machine does not washing but can spin
SOURCE: my LG washing machine model-fuzzy
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
SOURCE: I have a LG fuzzy logic the problem is that its not stopping the water input its over flowing ....
When you press the "SPIN SPEED" button and "SOIL LEVEL" button the water
level frequency should be above 246. If the water frequency level fails
to reach 246 in 8 minutes you will get an IE error or inlet error. You
would need to check the water valve, water pressure, etc.
How does
the machine know if the water level is complete? Water level switch
right? So obviously the control is timing the amount of time it takes
till the water level switch kicks off. If it takes more than 8 minutes
we have a problem don't we? Therefore if something is partially blocking
the tubing from tub to switch that might throw off the water level
switch. It is located on the main control assembly and has the rubber
tube connected to it. The control board uses this to determine water
frequency level. Just blowing the sediment out of that tubing will cure
the IE error IF everything else mentioned is all good. I meself would do
that first before replacing any parts.
LG WASHER MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Call LG's support line, they have excellent customer service.
