Cars & Trucks Logo
Fatima Angle Posted on Sep 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the location of starter and the fly wheel
john h
Level 3:
Top Expert:
  • Cars & Trucks Master 29,494 Answers
  • Posted on Sep 11, 2016
john h
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7559657
Points
193449
Didnt specify vehicle---generic answer flywheel is located bolted to rear of engine and is sandwiched between the rear of engine and transmission the starter is bolted usually towards bottom corner at rear or side of engine
Starter engine starter flywheel diagram Yahoo Video Search Results these links show various starter/flywheel locations
Flywheel or something grings against the starter when clutch is engaged
There is no way the ring gear will hit the starter pinion unless the fly wheel bolts on the crank shaft or loose allowing the flywheel to run out of true. If you have had clutch/ rear seal work done lately the fly wheel will only fit in one position and if that was ignored at some time then the fly wheel will run out and touch the starter pinion.. I would also check the adjustment on the starter pinion as it has to be set by the lever pivot to a correct distance or it will touch the teeth of the ring gear
Starter relay location
Sounds like the starter is going bad it is located on the engine no pun intended . The starter will be located where the engine and the transmission come together that is called the bell housing. The starter starts the car by way of the fly wheel dont worry you cant see the fly wheel just a little FYI. If you change it your self make sure to unhook the battery first to prevent a spark.
1helpful
Bad starter
It is either a bad starter or a bad fly wheel. What happens is the teeth of one or the other wear down. If you are turning the starter several times and it finally starts then you have a bad spot on your fly wheel. One way to check is to pull out the starter and look at the teeth on it. If it is your fly wheel it should be replaced but you will have some time. As the wheel turns you will probably not hit the bald spot on it that often.
I own a1989 Lincoln vii lsc and I need to know where the starter is located and how much a replace one. rebuilt
STARTER UNDERNEATH CAR LOOK WHERE FLYWHEEL LOCATED YOU WILL SEE STARTER AT FLY WHEEL COVER. STARTERS CAN COST FROM $100.00 OR LITTLE MORE.BUT CALL AROUND GET A PRICE CHECK.
2answers
Locate the starter on my 1991 isuzu trooper v6
the starter is located at the bottom rear of the engine, u access it from under the truck.
2answers
Where is the starter located on this vechicle
The starter should be located under the exhaust manifold on the front of engine. Since it is a front wheel drive, the front of engine is the side near radiator. Slide under front end and look up. That is where it should be located.
12helpful
2answers
Where is the starter located on a 2002 Monte Carlo
under the front of the car right behind the radiator, its silver and about twice the size of a pop can, you can replace it with out taking out anything to get to it, its just a *****
2answers
Car wont start and have been told it is the starter, where is the starter located? It is a 2004 chrysler sebring convertable!
The starter is mounetd to the bottom of the engine either left or right of the fly wheel..
Look for the fly wheel.. Really big round gear.. The starter spinns that big gear & turns the motor..
Good luck..
Rate me good ;o)
I have a 1990 Jeep grand Wagoneer and iam having a problem locating the starter, help
You need to get under the front end of the truck - safely...
To the left or right of the fly wheel.. The fly wheel is a realy big round gear..
The starter will be mostly sylinder shape..
Should be easy to find..
Starter turning engaging not start
 you need a shim, if its screaming your clearance is to great. Are you positive its the right starter?
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
