Question about Goodman GMS90703BXA Heater
Goodmans digital radio model GMR1888DAB. How do you substitute pre set channels
How do you set up a channel on the radio to listen to
Without knowing what you have, I cannot guide you. Consumer radios are pre programmed, meaning they have the channels installed. Business band radios must be programmed by a radio shop because the FCC regulates their channels. So, a picture or model name and number is the only thing that will help us help you.
Such as Motorola, T3180. do not list an FCC Type acceptance number.
Sep 03, 2017 | Radio Communications
Hi my mother's Goodmans LD2614 tv has lost all pre-set channels, and she has lost the book that came with it. Phil
Unfortunately, this TV model was made by Comet under a license from Goodmans. Comet held all the technical information related to the model. Comet's business failed. If it was a warranty matter, you might get something. But you are not going to get technical support. That said, the 050 code entered into a remote being used to setup the TV may be of help.
http://www.tvtuning.co.uk/makes/goodmans.htm
http://www.wowforbusiness.com/docs/wow/product-support/digital-adapter.pdf
Maybe the above pages will be of help.
Aug 09, 2017 | Goodmans Televison & Video
Goodmans TV needs re tuning
Very likely that where you are the over the air signals are now broadcast in digital format and you need to by a converter box to use an older television. Check places like Walmart or Best Buy or Radio Shack
Apr 13, 2010 | Goodmans 15.4 in. LCD TV/DVD Combo
Where can i get driver for goodmans g-shoot 3000cc digtal camera
have a read here https://www.fixya.com/support/t179661-drivers
The goodmans suppoort site does niot have any software drivers http://www.goodmans.co.uk/productdetails.aspx?pid=G-SHOT3003CC&language=en-GB
Copied from the link FixYa BY djnick989 Jan 30, 2008 - Goodmans A trading name of Goodmans Industries Limited Goodmans Industries Limited is the operator of this website.
Pre-purchase enquiries: e-mail: archbolda@albaplc.co.uk Address:
  • Goodmans Industries Limited
  • Bush House, The Waterfront
  • Elstree Road,
  • Elstree
  • Hertfordshire, WD6 3BS.
Many Goodmans products may be purchased direct, please click here to find out more.
Product, order and post sales enquiries: e-mail: cecustomerservice@albaplc.co.uk Telephone: Technical Support Team: 0871 230 1777 Ask our Technical Support team a question.
Apr 13, 2010 | Goodmans G-Shot 3000 Digital Camera
How do I enter a code into my BMW business rds radio (Philips) model
with the pre-set station keys, press 1 then then use channel up/doun to select correct digit..
then press 2 use again channel up/douwn key to select correct digit, repeat same with 3 and 4, then press pre-set key 5 that puts in the code,DONE!
O.K.?
Mar 10, 2010 | 1997 BMW Z3 Roadster
How do I retune my goodmans television for
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Oct 01, 2009 | Goodmans W280NS Television
How to pre-set radio channels
After some playing!
Use 'Auto-Scan to find required channel
Select 'Memory' ; 'Memory shows on control panel
While 'Memory' still shows, press preset button for required channel number
Programme is set
Jun 20, 2009 | Venturer Audio Players & Recorders
Cannot get my goodmans 289ns to accept the virgin digital signal
Will the TV go to channel 3? if not you need to reporogram the TV to sence channel 3 or go into the setup and undelete channel 3. Channel 3 is the channel your digital box is set to boradcast to the tv itself.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Goodmans 289NS 14" TV
Goodmans cd car radio
my guess would be to push the number you want the channel on and hold ot for 10 sec
Don
Jan 03, 2008 | Goodmans CD / MP3 car radio GCE780MPT CD...
Goodman GMS90703BXA Heater Logo
75 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Brad Scarpetta
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
