SOURCE: GE profile Clothes washer
SOUNDS LIKE THE TIMER IS GOIN OUT, NOT TO SURE, BUT SOUNDS LIKE THE CONTACTS ON THE TIMER IS ON ITS LAST LEG, GET THE MODEL NUMBER AND SERIAL NUMBER AND SOURCE AROUND FOR A REPLACEMENT TIMER............
ITS REALLY EASY TO REPLACE..........
GOOD LUCK........
SOURCE: water will not stop filling wash basket, even when off
Your water fill (mixer) valve is failed in the open position.
CLICK HERE for the part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: my ge profile washing machine went off balance and
Hhi, It could be the basket brackets have jump over the shipping bracket and will not let the basket center it self.
There are 2 clips in the gap between the top and thefront panels. use a flat blade and push in on the clips releasing the front panel. It will lift off. The bracket I mentioned is located under the motor. There are 2 brackets and they have holes in them. If the basket is lodged against these 2 brackets, just bend them down toward the bottom to get htem out of the way. They serve no purpose. While you have the front off, the basket hangs on each corner. Make sure eash corner is still attatches to the hangers.
I hope this helps you.
Please let me know if I can assist you further.
Vic
SOURCE: Ariston - Margherita Washer -dryer model AWD
Check motor brushes for wear. Brush length is about 30mm new; 10mm or less is too short to do what they're meant to.
SOURCE: My GE washer basket makes a rattle sound when
The best option is to look at the source of noise than to specilate on a whole list of possibilities.
Please use a good lighting to look from the underside of the washer . Now rotate the main shaft, rotate the drum and check.
The fault can be poor spindle assembly, check bearings, belts.
Also it can be that some foregn objects have lodged into the tub from any clothes during the wash. so check this out, if so remove after dismandling.
Please proceed to check and respond.
Helpful?
