SOURCE: how to get the messages of doro 615R+2 digital phone
down the bottom right corner , on the hash button, see the little x sign under the key, when you have listen to a message push that and it will be deleted then the next one will be heard and repeat untill you finish. hope this helps
SOURCE: doro phone
only just found this out as this was my previous question, but i just started fiddling with my ph. so here's the answer.
press the little c button (top right corner)wait for 5-6 secs then press 9, 180 will show on screen thats the amount of time to say message. to hear it repeat but press 7.
hopw this helps
SOURCE: Doro 5065 - changing outgoing message
Go to:
http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
Type in your phone model number. Scroll down to PDF and download in your language.
SOURCE: Doro 830R phone- how to reset answering message to default?
Well, I'm sorry to say that I've spent the last hour trying to find a way for you to reset this to factory & it looks like you can not. I had a hard time believing that (which is why it became an obsession) but, I think you're going to have to ask a neighbor to record a message for you. Actually, that sounds like fun :-)
Good luck.
Push the top left button (looks like an audio tape).
Then push 5 (has a play symbol on it)
You can use 4 and 6 to navigate saved messages or use # (has a 'X' on it too, to delete messages).
To turn off/on the answering machine:
I lost my user manual for my Doro 615R+1 home phone, so after much deliberation and playing with many buttom combinations, worked out how to turn off the answering machine.
- Open the answering machine function by pushing the top left button (looks like an audio tape).
- Push '0' and then use the up and down arrows to select On or Off.
- To enter your selection puch the top right button (looks like and arrow into a diamond).
Done :-)
