SOURCE: Caller ID not working
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
SOURCE: panasonic kxtd816 with caller id card kxtd-193 problem kxt-7431
All Panasonic display phones, both analog and digital 7xxx series phones support CID. It requires 5 or 6 program adjustments as outlined in the manual. With luck, you may be able to just turn it on in 406, but your area code needs to be set if you have 7 digit local dialing, you need to tell the system if you want CID to adjust the clock daily, SMDR display, etc.
The 1232_PG lists all the steps. If you don't have a manual, you really need to get one. Post back and we'll see what we can do.
Carl
SOURCE: caller id is not displayed anymore
i dont know how your sistem ist working. Im just looking for a instruction for the RX-DS45 to change or add the radiochannel
SOURCE: how will i activate the caller ID?
What phone system is the 7730 connected to and do you have CID hardware?
SOURCE: CALLER ID NOT WORKING
not only Panasonic, most other brand phones imported from other countries wont work in in India ( caller ID). Panasonic phones of Panasonic India, will work.I think panasonic has to explain this. if there are networks which does not support this equipment, atleast they should mention this is their booklets, to avoid users roam around telecom offices. To my understanding, all the land phones of BSNL through out India are caller ID enabled by default and is free!.
Check your Sim in another phone to confirm , if there is no CLIP then the service provider has barred you and must get in touch. Also is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
