Intermittent on and off continuously, with a reboot like sounds but nothing happens. Need help. Thanks.
Hi Carlos, error code 3 & 4 is caused by faulty RAM (Memory modules) installed in the PC. You could try the following to resolve the issue:
1. Open up the computer cover
2. Locate the memory module(s)
3. Remove them memory module(s)
4. Use a can of compressed air or spray contact cleaner onto the center of the DIMM connectors to clean all the contacts. Do NOT use a normal brush to clear dust away. Wait for 5minutes for the contact cleaner to dry.
5. Reseat the memory module(s)
6. Turn on the computer and check if codes 3 & 4 still light up. If it does not, it should boot into the Operating System.
7. If codes 3 & 4 continues to light up, you will need to run a memory diagnostic test to determine which of the memory module is faulty.
Thanks for your inquiry, Barbara Williams!
I understand that the lights on your Frigidaire washer are blinking and beeping. It sounds like your washer is providing a set of error codes. Your control panel may need to be replaced. I would recommend contacting a professional technician for proper diagnosis to be completed to avoid any unnecessary part purchases. Hope this is helpful. -Matt
