Serial no 0107455. Hoover Frost free Refrigerator/freezer class 6
SOURCE: freezer no frost
This is probably due to the failure of defrost timer or the heating coil..Try this
1)The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
2)If this doesnt work then Test the heating element for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should display a reading somewhere between zero and infinity. Because of the number of different elements we cannot tell what your reading should be, but we can be certain of what it shouldn't be. If the reading is zero or infinity the heating element is definitely bad and should be replaced. Proper power ( careful!! ) to the heating element ( 110-120 volts AC ) and the defrost heater does not come on = bad defrost heater.
SOURCE: Samsung frost free fridge freezer - RL39WBSW
Dear friend,
ngfam at you service! happy to assist!
Sounds like two separate problems!!!
Do not delay!
Call service before you have bigger problems and a bigger expense!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
SOURCE: FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
SOURCE: I have a hoover frost free a class fridge freezer
sounds like a bad thermo stat it is not maintaing the proper temps in fridg area....
SOURCE: Frost accumulating on back of fridge - service light blinking
YOUR EVAPORATOR IN THE FRESH FOOD SECTION IS LEAKING FREON. THIS IS COMMON WITH EVAPORATORS IN THIS AREA. 12 PART WARRANY OR 6 YEAR FULL ON THIS. SUB ZERO HAS SUPERIOR CUSTOMEER SERVICE AND MAY COVER FULLY IF OUT OF THE 6TH YEAR. 1-800-222-7820 CALL THEM AND ASK.
