I need a schematic for replacing this belt.
SOURCE: The belt came off my mower and I need to know what
Try going to kubota.co.uk and see if a diagram is available there.
SOURCE: need to replace drive belt on cutting deck and
You will have to disconnect the deck from the tractor. There might be
some rods hanging down by the pulley on the motor. You have to loosen
those not remove. Then install the new belt with the inside of belt (V)
into the pulleys. The outside of belt (flat side) goes up against any
idlers (oversized pulleys). Once you get the belt routed properly the
belt will be snug in the pulleys. If you have excess play you have to
use trial and error to get the belt routed the right way around the
idlers.
Once belt is on reattach the deck and tighten the rods by the motor
that keeps the belt from coming off. They need to be close but not
touching the engine pulley.
Good luck and let me know if this helps.
roundo4
SOURCE: I need a free diagram of the belt assembly for a
Good luck. It looks like the diagrams are all locked down by Kubota.
I might recommend looking throught the listings of "kubota empart" empart is the parts lookup system used by dealers and there are sites out there that may have kubota listed.
Joe
SOURCE: I need a wiring schematic for a Kubota HK28L Excavator Please.
The brand you have does not post information on internet. But if give them your e-mail address. They will send it to you. www.messicks.com
