Try to find a more local dealer, or use a place like Edisons Australia,
https://www.edisons.com.au/parts/
as they do ship worldwide, as long as you can pay for the shipping.
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
SOURCE: Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
SOURCE: i have a new Baumr ag pro sx72 chain saw I have
Hello.
Your saw is an Australian product. Here is a link to learn alot more about your saw... http://www.woodworkforums.com/f132/any-baumr-chainsaw-owners-97389/
SOURCE: my Baumr Ag sx62 leaks bar oil.
The white plastic thing you talk about is spare impeler for the chain oil pump, but you should find it is a different thread which will slow down the oil flow, well it did for me. i have owned one of these saws for three years now and it still goes like a freight train. before you put them to use you must make sure the carby is set right. because if its running to lean or not enough oil in the fuel, Yes it will seize every time. All you have to have is a little bit of an understanding in small engine mechanics. Yes they do leak a little oil, just fill it when you want to use it. a chainsaw should use one tank of fuel to one tank of oil, no more than two tanks of fuel to one tank of oil.
SOURCE: Hi There, we've bought a
I have just bought one and the manual is hopeless but finally I figured it out. If you have installed the chain and guide you will need to remove them, then with the saw lying on the side and chain cover off you will see two holes on opposite side of the oil tank/engine casing
This photo shows the spike in position.
