Tivoli Audio Model One BT AM/FM radio with Bluetooth audio streaming Logo
Posted on Sep 04, 2016
How to fix the Off/AM/FM/AUX/BT selsct knob in a Tivoli Audio Model One BT radio?
When I turn the radio to the off position, the LED light remains on and the AM dial continues to play.
2helpful
Tivoli Audio Model Two OFF - FM - AM - AUX Switch
It sounds like there may be a problem with the switch or the connections between the switch and the circuit board. Here are a few troubleshooting steps you can try: Clean the switch contacts: Over time, the contacts in the switch can become dirty or corroded, leading to poor or intermittent connections. You can try cleaning the switch contacts with a small amount of contact cleaner or rubbing alcohol on a cotton swab. Be sure to unplug the radio from the power outlet before attempting any cleaning. Check the connections: The switch may not be making a good connection with the circuit board, or there may be a loose wire or solder joint. You can try opening up the radio (if you're comfortable doing so) and checking the connections between the switch and the board. Look for any loose wires or solder joints, and gently re-seat or re-solder them if necessary. Replace the switch: If cleaning and checking the connections doesn't solve the problem, the switch itself may be faulty and need to be replaced. You can contact Tivoli Audio customer support to order a replacement switch and get instructions on how to install it.
I Lost FM on my Tivoli Model One. While FM was playing I touched the radio and gave it a static shock (very dry climate) and lost the FM. AM and Aux are fine.
It will need to go to a service centre for repair. Most probably the static electric jolt will have taken out either the FM RF amplifier of the FM mixer, meaning it needs component level repairs :o(
Hello, I purchased a Tivoli Model One few months ago and I noticed that after tuning a radio station (strong signal, amber light on), the signal will fade out in ten minutes or so and I need to tune it...
hi,
it looks like its got a hookup for an external antenna on the back, hook a wire to it or better yet hook it up to a pair of rabbit ears, look at the back and make sure your hooking it up to the right connector am/fm
rabbit ears at walmart
..jm
Tivoli Audio Frequently Asked Questions Tivoli Audio
8260f424-51e7-404b-8aad-55d32a5ee6ab_1.c6ade34e7d92de1dbfde961d78f8c87b-2mys2t2nr3la4vnxyourkcko-2-0.jpeg
I bought my Tivoli Model One two months ago in Bogor, West Java, Indonesia. The sound quality on FM band is superb even if it's on mono mode., but I found the the signal reception on FM is unstable. I...
Many such problems are caused by bad aerial connections, aerial cable problems and the aerial itself. Make certain all of these are good before checking out the electronics.
Tivoli model Satellite will not turn on. Had intermittant power issues. Moved the radio and it will no longer power on
The power control problem is easy to fix.
It can as simple as a fuse (I'm sure you check it already) or a switch that is piggy back on the volume control.
Radio Shack has a similar one HERE
Disconnect the AC outlet and open the main Tivoli unit.
Look at the back side of the volume switch and you will see a power switch piggy back onto the volume control.
You can bypass it or get the correct value Potentiometer + SPST switch.
Use an ohm meter to meter the both end of the potentiometer and if it's 10,000 ohm or 10k then just go to Radio Shack and ask for
10K-Ohm Audio Control Potentiometer with SPST Switch Model: 271-215 | Catalog #: 271-215
It's a direct replacement.
If the ohm read is other then 10K then you will need to order it for an electronic supply house.
Tivoli makes great radio.....if you want to sell it I want the first dip.
1helpful
Loud buzzing and getting only AM reception on the FM setting. Any ideas?
Possible that the band knob has slipped on it's shaft or has become out of line or loose. Try pulling the knob off, making not of the position and see if the shaft is loose. Try to get back to me on this.....
1helpful
2answers
Get a lot of static when try and turn volume down low.....in fact, sometimes it is hard to get sound when you turn the volume down....it is either full blast or silent.....lots of static like noise when...
This is an easy fix with a can of volume knob cleaner i think its called. You should be able to get it at radio shack. You just spray it into the volume knob and let it dry. The instructions are on the can.
4helpful
3answers
Tivoli Model one radio - volume control does not go to quiet. I like to listen at night but volume does not lessen past a certain point which is too loud.
I noticed the same problem after I had moved. Hadn't had it before. The solution was easy in my case. (It took some time to accidentally figure it out though). I flipped the power cable around 180 degrees / upside down and re-connected. After this the volume worked as before. This was the model with European power plug.
Top Tivoli Audio Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Tivoli Audio Radio Communication Expert? Answer questions, earn points and help others
