I may not be understanding what you are stating, so bear with me;
1) The Wireless Modem antenna wires are up in the Display Assembly,
http://www.mundocorp.com/shopexd.asp?id=1160In otherwords they should already be there.
2) The 802.11 Mini PCI Card, is a Wireless Module.
It goes in the Mini PCI Compartment, under the Mini PCI Compartment Cover, located on the bottom of the laptop.
It's made by Broadcom,
(Gateway 6002672 part number)
http://support.gateway.com/s/Mobile/NETWORK/Wireless/6002672/6002672mv.shtml
See at the Top right where it states Main, and has a white Side Arrow?
This terminal is where the Black wire (Lead) of the wireless antenna connects to.
The other terminal, AUX, is where the White wire connects to.
http://www.laptops-we-r.com/prestashop/gateway-6000-parts/418-gateway-dell-broadcom-bcm94306mp-b-g-mini-pci-wifi-card.htmlHere is the Service Manual, (PDF file form),
http://support.gateway.com/s/Mobile/Gateway/600YG2/8508798.pdfPage 13.
REMEMBER, remove ALL power. Remove the AC adapter (Charger), and Battery, before working on the laptop. Also follow Anti-Static Precautions.
Regards,
joecoolvette
