Health & Beauty Logo
Steve gray Posted on Sep 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Digi weigh scale (hand held) powers on, then reads "LLL". Will not cycle thru calibration correctly . Can it be fixed?
Marlo Lampitoc
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 30, 2021
Marlo Lampitoc
Contributor
Level 1:
Answers
Questions
0
Helped
426
Points
Load cell error usually display LLLLL. The only way to fix it is to change the load cell or try to locate the analog to digital chip. Try to change the impedance(series or parallel a resistor)
Stan Ford
Level 3:
Genius:
  • Health & Beauty Master 3,131 Answers
  • Posted on Sep 03, 2016
Stan Ford
Level 3:
Genius:
Answers
3131
Questions
Helped
904504
Points
9078
Remove and refit the battery. this may reset it, if not replace it as the cost of repair will be more than a new one.
4 Related Answers
Anonymous
  • 279 Answers
  • Posted on Jan 17, 2010
SOURCE: New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Anonymous
  • 15935 Answers
  • Posted on Sep 05, 2010
SOURCE: Tanita BD-590 calibration
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
W.L.
  • 2511 Answers
  • Posted on Jul 19, 2014
SOURCE: I have fuzion rogue -650 digital pocket scales but
You can use the weight of coins to calibrate the scale. Since I don't know where you are here are some examples.
use the newest cleanest ones you can as they do wear and change slightly
http://www.usmint.gov/about_the_mint/?action=coin_specifications
http://www.royalmint.com/discover/uk-coins/coin-design-and-specifications
Terry Corrow
johnny rebel
  • 10875 Answers
  • Posted on Jun 26, 2015
SOURCE: how do i calibrate a salter 1008 scale
press 2
I replaced the batteries of my Omron Karada Scale BF511 and it's been showing Err. When I step on it, the scale reads up to a 110kg (and I weigh 76kg) before reading Error. Please help.
Here are some steps you can take to troubleshoot and potentially resolve the issue:
1. Make sure the scale is on a flat, stable surface: Uneven or unstable surfaces can affect the accuracy of the readings. Place the scale on a hard, level floor and ensure it is not wobbling.
2. Check the battery installation: Double-check that the new batteries are inserted correctly, following the polarity markings inside the battery compartment. Ensure there is good contact between the batteries and the terminals.
3. Calibrate the scale: Some digital scales require calibration after battery replacement or when experiencing issues. Check the user manual for instructions on how to calibrate your specific model. Calibration usually involves placing a known weight on the scale and adjusting it accordingly.
4. Clean the scale: Dirt, dust, or debris on the scale's surface or sensors can interfere with accurate readings. Use a soft, slightly damp cloth to clean the scale, ensuring it is dry before use.
5. Try weighing yourself multiple times: Step on and off the scale a few times to see if the error persists. This can help determine if the issue is consistent or intermittent.
My etekcity scale is showing a C shape on the screen after weighing something - what does that mean?
A "C" will appear during the first weighing, this is a self-calibrating feature on some scales. It means the scale is re-calibrating to zero. Please re-weigh for accurate reading. Scale will also re-calibrate after every battery replacement.
How to fix digital scale reading LLL
LLL probably indicates "Off-Level".Take batteries out / unplug power,re-apply power and make sure scale is Level....LLL also might indicate power is Low....make and model # ???
1helpful
Calibrate a mega weigh mgp-1014 digital pocket scale
Calibrating a digital pocket scale like the Mega Weigh MGP-1014 ensures that it provides accurate measurements. Here are the general steps for calibrating such a scale:
Note: It's important to refer to your scale's user manual for specific instructions, as calibration methods can vary between different models.
What You'll Need:
  • Calibration weights (these are weights with known, precise values)
  • The Mega Weigh MGP-1014 scale
  • A clean, stable surface for calibration
Steps:
  1. Read the Manual: Familiarize yourself with the user manual that came with the scale. It should provide specific instructions on how to calibrate the scale.
  2. Clean the Scale: Ensure that the scale's weighing platform is clean and free from any debris. This helps to prevent interference with the calibration process.
  3. Power On: Turn on the scale and wait for it to stabilize, displaying "0.0" or the default reading.
  4. Tare (Optional): If your scale has a tare function, you can use it to zero out the weight of any container you plan to use to hold the calibration weights. Place the empty container on the scale and press the tare button.
  5. Select Calibration Mode: Many scales have a calibration mode that you need to access. Refer to your user manual to determine how to enter the calibration mode on the Mega Weigh MGP-1014.
  6. Add Calibration Weight: Place a calibration weight of a known value onto the scale's platform. The weight should match the unit of measurement you plan to use (grams, ounces, etc.).
  7. Calibration Procedure: Follow the specific instructions provided in the user manual to initiate the calibration procedure. This usually involves pressing buttons or following on-screen prompts. The scale will often ask you to confirm the weight value of the calibration weight you added.
  8. Confirm or Adjust: The scale should display the weight you added as the calibration weight. Confirm that the displayed weight matches the known value of the calibration weight. If there's a discrepancy, follow the manual's instructions to adjust the calibration setting accordingly.
  9. Repeat if Necessary: Some scales require calibration with multiple weights to ensure accuracy across the scale's entire range. If this is the case, follow the manual's instructions for using additional calibration weights.
  10. Exit Calibration Mode: Once you've completed the calibration procedure, exit the calibration mode according to the instructions provided in the user manual.
  11. Test with Known Items: After calibration, test the scale's accuracy by weighing objects of known weight to ensure that it's providing accurate readings.
Remember that the exact calibration process can vary depending on the scale model, so always refer to the user manual for the most accurate instructions. If you're unsure about any step, it's recommended to contact the manufacturer's customer support for assistance.
When I turn on my digi pocket scale modelDW1000BC it reads LLL what do I do
I usu and hold itally turn on scale for a short time then hit m
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
