The feed dog control is the knob at the very bottom front, right side of the machine. If the feed dogs are not dropping, most likely the machine needs a thorough cleaning and OILING! I use Tri-Flow Synthetic Lube.
Bernina Record 930 Electronic seldom use like new Wheel will not move Was...
Instruction Manual for Bernina 801 need instructions for oiling the...
Bernina 930 Record Oil Diagram
How do unjam the gears in my bernina 830
Bernina 930 feed dogs won come back up Bernina Sewing Machines
SOURCE: Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
SOURCE: Bernina 1008 feed dog problem.
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
SOURCE: Is there a way to lower the feed dogs ''a little''?
I thought this was free . . . didn't know I'd be asking to join. So, I called the shop where I purchased the machine. They were able to help me fix the problem.
SOURCE: I hav e Bernina 1150. When I attach the walking
Hi, when you quilt straight lines using the walking foot, you need the feed dogs up, to move the fabric in a straight direction under the needle. When you do free motion quilting, which is done with a darning foot, your hands move the fabric in many different directions. Since you want to be the one to move the fabric, you put the feed dogs down and you do the work. So when you use the walking foot, keep your feed dogs up. When you use the darning foot, feed dogs down.
SOURCE: the feed dogs on my
Hi Annie, next to the bobbin case, to the right, is a metal lever to raise or lower the feed dogs. Press it and you will see how it works. Enjoy!
