SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
SOURCE: Flush valve drops before bowl completes flush
is the flapper weighted? if it is it will cause it to shut prematurely. one thing you can do is increase the water in the tank. you might have to buy a pvc cuppler to put on the over flow to allow it to fill up more. korky makes a nice flapper thats not weighted
SOURCE: Toilets are refilling between flushes
Replace the flappers, and clean around the flapper seat.
Make sure the water level is 1/2 " below the large vertical tube by either bending the float rod down or adjust the skinny silver rod on a Fluidmaster unit.
