Usually the stitch width selector would do that.
Um, just curious. If you are darning, you would manually maneuver the fabric to go forward and back and side to side. You probably wouldn't want to use a wide stitch for darning. Also, for darning, you would probably want to use a darning foot or free motion foot. They are both shorter than the standard presser foot so there would be no pressure applied to the fabric, especially when you drop the feed dogs. Technically, the feed dogs wouldn't be feeding the fabric, you would by hand.
https://www.youtube.com/watch?v=GtLj0iJnvqM
Remove yourcurrent presser foot from your sewing machine, and attach the darning foot asyou would any foot. Darning feet look different, depending on the manufacturer,but most will maintain a "C" or "O" shape using eithermetal or clear plastic at their bases.
Drop the feed dogs, or use a cover plate on your machine if feeddogs are not available. If this is not possible, adjust the stitch length ofyour machine to zero or as low as your machine will allow.
Slide your fabric or quilt sandwich into place below the darningfoot. Lower the lever of the darning foot, and hold onto the upper thread withone hand.
Take one complete stitch, and pull up the upper thread to bringthe bobbin thread to the surface. Take multiple stitches in the same place tosecure the threads.
Run the machine as you free-motion sew or quilt your fabric piece,using your fingers to move the fabric instead of the feed dogs, until yourstitching is complete. Replace the darning foot with your preferred presserfoot when finished.
Read more: How to Use aDarning Foot ' eHow.com http://www.ehow.com/how_5143471_use-darning-foot.html#ixzz1AprkDyhm
Thanks for rating
Good luck
