HP Photosmart C6180 All-In-One InkJet Printer Logo
Posted on Aug 28, 2016
Scanner unit hinges on HP Photosmart C6180. Is there a way to separate the unit from the main body of the printer?
I want to swap the scanner unit from one C6180 to another but I cannot detach the hinges. How do I do this?
5 Related Answers
Anonymous
  • 983 Answers
  • Posted on Feb 09, 2008
SOURCE: hp photosmart c6180
you are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
Remove the ink carts.
on either side of the carrage there is a screw, remove both of them.
CAREFULLY slide out the silver bar those screws are holding. Be sure to note its orentation for putting the thing back in later.
also carefully remove the silver "fingers".
remove the black clip/cover on the right side of the carrage that covers the ribbon cables.
lift the head (you see 4 nipples in there-- that is the top of the head assembly)
gently pull out the ribbon cables.
on the bottom of the head is 2 screws, remove them
now the head will come into 4 parts. Nipples, Gasket, nozzle block, and a metal guard.
get some windex with amonia.
soak the parts for a day or 2.
blot dry, then let it set for atleast 2 days to be sure it is COMPLETELY dry.
reassemble, charge the ink, do the printers head cleaning, and boom. back in business.
this works 90% of the time
Anonymous
  • 79 Answers
  • Posted on May 25, 2008
SOURCE: Can't scan from printer or computer
Close the Digital Imaging Monitor.
◄ Start or restart the services :
1. HP Cue Device Discovery.
2. HP Net Device Discovery.
3. HPQCS08.
◄ Run Digital Imaging Monitor.
◄ Wait for a Minute, if the configuration screen appears it is done else refresh the HP Cue Device Discovery
◄ Restart the Printer
◄ 99% chances of resolution and in the other cases a proper uninstall and reinstall is needed
If the issue still remains then :;
Added the files to the firewall exception list
C:\program files\HP\digital imaging\bin\hpiscnapp.exe (version 10 software )
•C:\program files\HP\digital imaging\bin\hpqscnvw.exe (other than version 10 software
•C:\program files\HP\digital imaging\bin\hpqste08.exe
•C:\windows\system32\hpzipm12.exe
•C:\windows\system32\hpzinw12.exe
•C:\program files\HP\digital imaging\bin\hpqtra08.exe
•C:\program files\HP\digital imaging\bin\hpqthb08.exe
i. 68: dhcp client
ii. 80: web server
iii. 137:UDP Port 137 netbios-ns (UDP)
iv. 139: netbios-Session (TCP),
v. 161: snmp. (UDP)
vi. 427: srvloc. (UDP)
vii. 5353: mDNS
viii. 9100: pcl/pjl print.
ix. 9101: debugging tcp recv/send
x. 9102: debugging tcp send
xi. 9103: debugging udp recv/send
xii. 9110: echo
xiii. 9220: generic gateway (scanning, pml).
xiv. 9290: scan.
xv. 9280: generic gateway
xvi. 2500: scan.
sagarjd
JD Kiran Sagar
  • 95 Answers
  • Posted on Nov 21, 2008
SOURCE: How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
Anonymous
  • 15 Answers
  • Posted on Dec 14, 2008
SOURCE: HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Anonymous
  • Posted on May 29, 2009
SOURCE: Error Remove and check cartridge on
does it print with the color cartridge
9helpful
2answers
My HP Photosmart 3210xi cartridge door is also locked in open
There's no sensor, it's just a spring and a plastic wedge thing.
Using a #10 torx driver, remove two screws holding the right-hand side panel from the printer. (one in the back, one on top underneath the ink access door.) Unsnap it and set it aside.
Disconnect 3 small ribbon cables and one 5-pin connector that lead from the printer to the access door/scanner.
Remove the lid from the flatbed, then remove the access door from it's hinges. Use the torx driver and unscrew the hinges from the main scanner body.
Lift the hinge assembly from the scanner and push the steel pin out, seperating the two parts of the hinge.
From there you should be able to loosen them up, remove the springs, lubricate them, or find whatever the problem is.
Reassemble and you're done.
2helpful
Scanner Failure
Scanner failure means the scanner is not making enough light to see the home position. It happens when the scanner lamp ages or is covered with dust. Cycle power is just power off and on again, and see if it goes away.
1helpful
Regards,
Sagarjd
k24674
Grand Canyon Tech
Grand Canyon Tech
