It sounds like there may be an issue with the control board of your Roger Black Gold treadmill. Here are a few things you can try to troubleshoot the issue:
Check the power supply: Make sure that the treadmill is plugged in and that the outlet is functioning properly. Try plugging the treadmill into a different outlet to see if that resolves the issue.
Check the control board: Inspect the control board for any visible signs of damage, such as burnt components or loose connections. If you see any damage, it is likely that the control board will need to be replaced.
Check the motor: If the control board appears to be in good condition, the issue could be with the motor. Check the motor for any visible signs of damage and test it to see if it is functioning properly.
If you are unable to diagnose the issue or fix it yourself, it is recommended that you contact the manufacturer or a qualified technician for assistance.
Check the cable from console to motor control board. It would be a detachable connector on both ends. Try removing and reconnecting it. Sometime such problems can occur because of the bad contacts of connectors.Please remember to remove the power before attempting any service inside treadmill.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
If the recalibrate doesn't work swap the red and black wires on the incline motor and re plug the treadmill to the wall and let go all the way to bottom. Unplug then remove wires from incline motor and tape off. At least then u can still run on it. But incline feature is no longer an option
see the video attached. lube the rollers bearing front +back. However you must test the terminal motor voltage with multimeter, if there ARE THE MOTOR IS faulty. see my personal TIPS. 2) test the measure output voltage from control board for input voltage terminal motor if there ARE NOT, the board is faulty. God bless you
Unplug the treadmill. Locate the console key and place the
safety or reset key into the treadmill console. Replace any parts that
need replacing, or move on to the next step.
Locate the reset switch on the underside of the treadmill
console. Usually the button is large enough to trigger with a pencil
eraser or Q-tip. Plug the treadmill plug back into the wall. Use the
Q-tip to press the reset button. It may be necessary to hold the reset
button down for a few seconds. "CL11" will appear in the display of the
treadmill.
Press the reset button one more time with the Q-tip. "CL21"
should appear on the screen. Press the enter key. The display will
change again and show "CL22." Keep pressing the enter key until the
numbers cycle through to the number "CL26." Press enter one more time.
The letter E should appear on the display screen.
Press enter twice more. The letters "SS" should appear on
the screen. When this happens, press the start/stop key. Making sure to
keep well away from the tread, press enter to start the treadmill. The
treadmill will start on its own. The treadmill will stop on its own
after a few seconds. When it stops, press the power key two times.
Remove the safety key and put in a safe place. Your treadmill is reset.
resetting the treadmill especially on most merit treadmill is as easy as pressing and holding the "STOP" button until you hear a beeping sound and the display shows all zeros.
