Fuse is Solder mounted on the Circuit board behind the Headphone Jack..The fuse is on the Secondary side of the Transformer... not the primary... The Primary winding has internal thermal fuse. Fuse on PCB is 3 amp. Im working on one now that has a blown U3 ( IC output device)
Not sure about the KB-1, but many newer Peavey amps
( A Vyper for example)
have the fuse soldered to the circuit board.
If you're going to go through the effort of soldering, I'd suggest buying, and soldering in, a rear panel accessible fuse holder, so you only need to do it once.
