Question about Building Materials
Somebody stole my garage door opener out my truck...I bought a universal opener...but I cannot find the learn button on the stanley model 440 garage door opener..any help would be greatly appreciated
    Top Expert:
  • 22,486 Answers
Anonymous
SOURCE:
pgh_pa_guy
  • 2992 Answers
SOURCE: My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
Posted on Dec 01, 2008
Anonymous
  • 244 Answers
SOURCE: clearing codes on liftmaster garage door opener with yellow learn button
you seem to be doing right thing, hold learn button for 10 seconds, this should clear out all coded items; keypads, remotes.
Posted on Jan 15, 2009
Anonymous
  • 30 Answers
SOURCE: i installed a model hd900d
My best advise to you is get the brand name remote for your opener. I know it sounds like a pain but click brands are not super great because there supposed to work for many different kinda. For the most part you can call your local garage door dealer and pick one up for your opener. They may sell you a lift master brand opener which is find sears/liftmaster/chamberlain are all the same. Should only be about 35 bucks if you pick it up
Posted on Feb 10, 2009
Anonymous
SOURCE: Sears garage door opener
I just found the solution for my 'ancient' Sears garage door opener, model # 139.655000, and I figured I'd share it.
There's a separate radio module, wired to the main opener. This module is small, has a short wire/antenna, and plugs directly into an outlet.
There's a manual open/close button on this module (I didn't realize this until I got up on a ladder). This button is also a removable cover; underneath it is a "smart actuate" button -- this is your learn button.
What I did was: unplug the radio module. Pry off the cover. Plug the radio module back in. Hold down the button on the remote. Press the "smart actuate" button. This programmed my remote successfully!
Posted on Sep 21, 2009
Don Maggard
  • 3197 Answers
SOURCE: Automatic Doorman model 455 learn button location?
The button should be on the back of the motor unit. You may have to remove a light lens to find it.
Posted on Oct 06, 2010
Stanley garage door opener model 440. need a manual
Try Googling (Stanley)(440)(manual) without parens.
Apr 02, 2018 | Building Materials
Someone stole my garage door remote from my car. can i change something in or on my unit to render it useless when the thieves return hoping to gain entry? my opener is a shaft liftmaster ...thank you!
Locate the smart/learn button which is near where all those white wires go. Press and hold this button for 6 seconds. This will erase the memory of your opener and no remotes will work. You now need to program your remaining remotes.
Press and hold the button on your remote and then press and immediately release the smart/learn button. Do this for each remote you have.
Sep 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
I want to know if a universal wireless touchpad can be added to a Stanley Quiet Glide Garage Door Opener? If so, how do you set it up, I did not see any smart button or dip switches?
Hi - did you have any luck? I just bought a Skylink universal remote from Cdn Tire and don't see the "smart" button or dip switches on my Stanley remote or motor casing. There is a learn button on the casing but that appears to be for the door to "learn" the proper setting to go up and down and has nothing to do with the remote. Thanks!
Dec 20, 2010 | Locks & Locksmithing
I recently bought a house which has a craftsman 1/2 HP garage door opener. The garage door opener works fine using the wall mounted pad and also the numeric key pad, but not with the remote that came with...
If you didn't, try programming the remote this way.
Press and hold the button on the remote and then press and immediately release the smart/learn button on the motor unit. If this doesn't work you need to make sure you have the correct remote for the model opener you have. Your model number doesn't bring any results from Sears Parts.com.
Nov 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a clicker model KLIK2U and forgot the code. How do I reprogram without the old code?
It's really easy to reprogram your unit:
Step 1. Hold down the (*) and the (#) keys until the keypad stops flashing.
Step 2. Determine your opener ID using the list below:
*1= linear garage door openers manufactured from 1997 to
present.
*2= Chamberlin, Sears, Craftsman, LiftMaster, Master
Mechanic and Do it garage door openers manufactured from
1997 to 2004 ( Orange learn Button)
*3= Same as *2 above, but manufactured from 2005 to present
with a (Purple learn Button)
*4= Same as *2 above, but manufactured from 1993 to 1996
with a (Green learn Button)
*5= Genie Intellicode and Overhead Door garage door openers
manufactured from 2005 to present (315 MHz).
*6= Same as *5 above but manufactured from 1995 to present
(390 MHz).
*7= Stanley garage door openers manufactured in 1998 to
present.
*9= Wayne Dalton garage door openers manufactured
in 1999 to present.
Openers with learn Buttons
Programming: Enter the PIN that you want to use, remember
(4) digits only. then press #
Enter ID # from list above, for example 2 then #
Press and release the Learn button on your
garage door opener.
Enter your (4) digit PIN and press (0),
for Genie and Overhead door units press
(0) twice. To test and use wait for light to go out
on keypad, Enter you PIN and press (0).
Note: If opener doesn't function repeat programming.
Instructions if required.
Sep 17, 2010 | Universal Garage Wireless Keyless Entry...
Universal garage door remote
I have a feeling your neighbor operated their door opener when you were programming your new clicker. Try erasing the memory of your opener and then program the clicker again making sure your neighbors do not operate theirs at the same time. To erase the memory hold the smart/learn button in for 10 seconds.
Jul 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
500 people viewed this question
Top Building Materials Experts
Tom Chichester
Lawrence Oravetz
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
