I want to update my map on a dnx8120 and would like to know if i should wait or the update is relatively new? my map is out of date 2008. If you suggest update, how to order and install?
Amazon.com, Inc.
Rating: 3 - ‎19 reviews
Amazon.com Product Description The Nextar M3 is a great way to add GPS to your arsenal. ... The M3 includes a 2 GB SD card pre-loaded with maps of the 50 U.S. states with over 1.6 million points of ... Date First Available, July 1, 2008 ...
askville.amazon.com > Consumer Electronics > Car Electronics & GPS
Nov 17, 2011 - Similar Questions: NEXTAR 2008 M3 03 DATE MAPS ... There may be some leftover Nextar map update SD cards floating around in the retail chain. ... http://www.ehow.com/how_5901587_update-maps-nextar-gps.html ...
The Garmin GPS are among the easiest to use and they have the most complete mapping on the market. To update the mapping, there are several versions of the software integrated into these road gps. To name a few, city navigator version 8 and City Navigator 2008. With a newer version, you have the most recently built streets, new shops, new parking lots, etc.. To update, there are several ways to proceed. First, before you update your maps, I recommend you check if there is a newer version of the maps, visit garmin and download the plugin. You can also view the maps version directly on your gps.
Area maps are not drawn up every year. There is easily a several year gap before mappers get back to any given area to map any new changes since the last mapping. If that bridge was just opened, mappers wouldn't have had a chance to add it to maps, allowing it to be added to the map software so you could update your gps device. Basically, the bridge was too new for your gps to know about it's existence yet.
nope im afraid you will have to cough up for the new maps (map corrections etc will only show new one way directions, and new or adjusted POIs), might be a good idea to wait till brand new maps are available before you splash any cash, good luck
Verify the map version by touching the wrench and then Map and the Mapinfo. You should see something similar to the following. The lastest map is 2008. If you have purchased your unit with in the last couple of month, then you are entitle to a free map upgrade from v8 to 2008
Garmin puts out map updates on a regular basis. You must purchase these. The GPS comes loaded with maps that are current as of the date of production of the unit. It cannot "know" when new roads are paved and new subdivision are created without being "told" via map updates. The unit knows where it is in relation to the maps loaded on it by receiving signals from the GPS satellites in orbit. If things change, the maps must be changed in order for the unit to give you correct directions.
