Dryers Logo
Natasha gray Posted on Aug 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tumble light in drum is on but the pannel with buttons isnt the fuse broke before this and I changed it it worked for two days then this happend
Ned Halaweh
Level 2:
  • Expert 240 Answers
  • Posted on Aug 27, 2016
Ned Halaweh
Expert
Level 2:
Answers
240
Questions
0
Helped
49841
Points
502
Sounds like a thermal fuse again.
Your dryer is getting too hot and that's why it keeps blowing the fuse.
You will need to check the vent airflow and make sure it's not clogged. Best of luck
Ned
I changed my brakes on my 07 Prius front and rear. New rotors and pads along with back drums and shoes. Problem, ABS light and brake light came on at the dash, How do I get them off
Look at the old drums they might have a and pickup ring or magnetic ring , if they have I bet the new drums haven't. Some come off the old ones and put on the new . That's where I would start cus it's somthing thats happend since the brakes have been done
2answers
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
2answers
2answers
Dash lights and running lights arent working?!?
Check your fuses, after replacing fuse make sure you reset.
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
The drum isnt moving on the Hotpiont Aquarius VTD00 Tumble Dryer, prior to that i smelt burning and it stopped moving soon after that,
may be the motor but here is a website that will help, Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Jan 11, 2011 • Dryers
2helpful
The dryer is getting power but the barrel isnt turning
If motor runs but no tumble, belt is broken. It broke due to overloading, old age, or bound up tension pulley or drum support wheels. You have to check all of these when replacing belt. Belt is fairly cheap.
3helpful
2answers
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
2answers
How do I fit a new drive belt for my Kenwood KVT1W Tumble Dryer
I am not familiar with this machine but most dryers have to have the front removed so that you can slip the belt over the drum. I would imagine they have the screws hidden pretty well. Perhaps their is a removable front panel. Some have a few screws on top then you raise the controlpanel exposing the front screws. Just a guess.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Top Dryers Experts
john h
