Hi I have a Suzuki DT 16 engine 1602 no 207668
I have no spark at the plugs I have put a volt test on the green going into the CDI unit about 3 to 4 volts when pulled what should it be
Thanks
Mike
With or without remote control??
Disconnect the black/red wire from the CDI, if you have sparks, kill circuit shorted.
No spark: check coils
1 . The two pulser coils are located at 1 80°angles to each other and the
condenser and battery charge coils are also located opposite of each other
under the flywheel.
2. Remove the engine cover.
3. On models equipped with electric starters, disconnect the negative
battery cable.
4. Disconnect the connector and black ground wire.
5. On the No. 1 pulser coil, connect the digital multi meter between the
black/red wire terminal in the connector and the black ground wire. And the
No.2 coil between the white/green wire terminal in the connector and the
black ground wire. Resistance should be 260-380 ohms.
6. On the condenser charge coil, measure the resistance between the
black/red and green wires. Resistance should be between 1 70-250 ohms.
7. If the resistance reading is not within specification, replace the faulty
coil.
8. On the battery charge coil, measure the resistance between the
yellow/red and yellow wires, red and yellow wires (DT1 5MC) or the red and
yellow wires (DT15CE). Resistance should measure between 0.2 and 0.5
ohms.
9. If the resistance reading is not within specification, replace the faulty
coil.
