Televison & Video Logo
Posted on Aug 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung UN32EH4003FXZA version QD06, and have no picture. I have done the flashlight test and do see an image on the screen and have sound. Would it be the power supply or the main board.
No picture, but have sound. No back light but have image on screen using a flashlight.
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Aug 19, 2016
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987242
Points
237762
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Testimonial: "I could not find any information on the website you suggested about power supply board BN44-00664A. I believe that the back-light inverter is part of the power supply. I'm not sure if I should have voltage to both pairs of wires coming from power supply to the LED's (D+ & D-, S+ & S-)? I only have voltage coming from the "D" pair."
Samsung UN55J6200AFXZA. Lost picture and sound. Fuse on power board OK. Replaced power board and it did not solve my problem. Did flashlight test and I can see an image on the screen.
Samsung has self diagnostic software built into the setup section on your settings. There you can test sound, display and more. Give it a try, maybe that's where your answer is. It solved my sound problem. also check to see if it has a back light, like a monitor or laptop screen would have. If its bad you could replace it. Have fun.
Lynn
Samsung tv, model UN39FH5000FXZA. Have sound, no picture, black screen. no backlights. flashlight test shows image. What should I replace?
Lamps in the panel are bad...DON'T order the power supply like someone says on about every post he answers before testing the LED lamps or you will waist a lot of money.
TV has sound but no picture
The Audio and Video are two separate components and operate independently of each other. Therefore: The Video portion requires technical repair by a technician with the proper test equipment.
2answers
How do I fix a black screen on my samsung UN32EH4003FXZA?
Most likely the back light US you will need to get it look at if it's economically viable that is, try YouTube as thats what I would do to find out if I could do it myself. Regards David
1helpful
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Samsung led tv un55h6203af doesn't have any back light but has sound
If you have done the flashlight test and an image is present on the screen when the light is shined from behind then the backlight or the backlight regulator is defective, both should be replaced.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
