B
Brian Brennan Posted on Aug 18, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to unlock my home theatre so that it can play dvd from every region. It is asking me for a 2 letter code as in AU for Australia. What would the 2 letter code be for region free?
I went in to the region area of the menu and put in a code which i think is 8888. It then brings up the code AU which is for Australia (where I live). This is highlighted so that I can change it by scrolling through all the letters of the alphabet to change it but I don't know if there is a letter code for region free.
Mark Schmit
Level 3:
  • Master 1,915 Answers
  • Posted on Sep 04, 2016
Mark Schmit
Master
Level 3:
Answers
1915
Questions
0
Helped
753239
Points
7967
Most products by agreement with content producers, do not offer the option for region free, or at least they did not in the past.
Dvd codes lg
Hi Elizabeth. Not all DVD players are able to be made "multi region". The model numbers of DVD players that are multi region have the same model number as a "home" region player. There is no difference in the appearance of the unit. If it was sold to you by a retailer on the understanding that it could be made a multi region, then I suggest you call them ask ask for the code. Quite often, there is a procedure to follow when converting a DVD player to multi region - along the lines of - place the non region disk in the tray and press buttons X, X and X. I know this doesn't answer your question but I hope it gives you an explanation!
1helpful
2answers
2answers
I have an LG Home Theater Model HB806. It will play only DVDs for Region 4 (Australia and Pacific). Do you know the code sequence to unlock that restriction and play all Regions?
Your home theatre, because it's a BR player, has been made specifically for that region - the region for both the DVD and the BR is hard coded in the processor chip. Because of that there is no other region to switch to so you would need to replace the processor to change the region without making it region free.
Sorry, there is no way of making it region free.
2helpful
RECENTLY I HAVE BOUGHT A PHILIPS HOME THEATRE MODEL - HTS 3265 . ONE DAY I WANTED TO PLAY STAR WARS MOVIE DVD INTO IT. BUT NOT OPERATING.IT IS SHOWING REGION AND STOP PLAYING. PLEASE GUIDE ME FOR THIS...
HI,
ur dvd player has region lock . it will not play all the disk. check the DVD OF STAR WARS MOVIE which region it belongs. jus try the following not sure is it work or not
Open the tray. Press 99990 on the remote.
by doing this ur dvd player will become region free
then insert ur dvd and try.
for region 1 and region 2 code is 99991 ,99992 respectively.
feel free contact through fixya.
ok
I have a Samsung HT BD2 region 4, I go many region 1, they wont play, how can I make it play?
To unlock the DVD code its defends upon what region you belongs or from were you bought the DVD unit. Just click this site to hack the region code ; http://www.videohelp.com/dvdhacks
To keep it simple, this means that DVD players and DVDs are labeled for operation on within a specific geographical region in the world. For example, the U.S. is in region 1. This means that all DVD players sold in the U.S. are made to region 1 specifications. As a result, region 1 players can only play region 1 discs. That's right, the DVDs themselves are encoded for a specific region. On the back of each DVD package, you will a find a region number (1 thru 6).
The geographical regions are as follows:
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
The end result is that DVDs encoded for regions other than Region 1 cannot be played on a region 1 DVD player, also, players marketed for other regions cannot play region 1-stamped DVDs
Hope it may help you;
Regards;
VOTIT
12helpful
2answers
Unlock Region Code for LG XB12 Mini Home Theater
Below is the only known process to unlock the region settings on that model of dvd player.
Make sure there is no disc in it
Turn on by pressing "Power"
(--------) apears an "No Disc"
Press "Pause" on remote and "314159"
"Code" apears
Press "0"
"Code 00" apears
press "enter"
Turn off and on
Hope this works for you, let me know. If it doesn't then there are no available region hacks for your dvd player.
Thank you for trying Fixya!
Unlock the coby DVD-755 to free region use
I believe this works - I've yet to try it myself! Coby DVD-755 1 user region code/hacks August 13, 2007 Post region code/hack comment Region code hack posted by Peter, August 13 2007: DVD -755 from Walmart home theatre for $79.00 1-Press ?Setup? 2-Press Vol +, Vol-, Vol +, Vol -, 3-Number shows up 4-Change the region code by using RIGHT arrow. 5=Press ?Setup? to exit. Succesfuly tested bt Peter F.
4helpful
3answers
Phillips LX3600 Home Theatre
Power up the set and open tray in DVD mode.
Press <9999> follow by <X> buttons on the Remote control.
where x = numeric 1 to 6 denoting the regions below:
Then show your region on TV
1 = USA
2 = Europe
3 = Asia Pacific
4 = Australia, New Zealand, Latam
5 = Russia, India
6 = China
0 = Code Free
This is taken from the original service manual for the reciever
Top home Audio Players & Recorders Experts
NOEL
NOEL
 Grubhead
Grubhead
Are you a home Audio Player and Recorder Expert? Answer questions, earn points and help others
