Nibp is not recording ,
What do youmean by not recording ? Is it actually getting the pressure but not recording on paper ? If it is not getting a pressure at all , does it give an error on-screen ? (time-out etc. ) These NIBP units use a pump and there may be a leak somewhere in the line from pump to cuff . If you have another unit or any Mindray unit with NIBP , you can troubleshoot using another NIBP line . Unplug the exisiting and try another line . If not verify the cuff does not have a leak and you can run a leak test withing the unit itself . If you do not have a manual , you can get one online from Mindray or other sources to describe in detail how to run the leak test .
What do you mean by "how can I install it"?
It doesn't install, it works by itself with a transducer.
