SOURCE: Yellow on all color printings
What photo program do you use? Is the yellow background on all Word doc's? You should check WORD go to the Format|Background make sure "no fill" is selected. You should also check your print properties in control panel and any special program DELL uses. Make sure there isn't some custom setting that is printing the yellow background. Let me know what happens. Good Luck, Tim
SOURCE: Background Color
1) In the Applications Menu on your copy screen there should be a option to turn on or off a background color fill. Turn it off and try. If it still comes out try hitting panel reset. If this doesnt work. 2) You have a bad Image Unit. Change the yellow image unit. 3) You may also have a bad write unit. Pull out the four write units and check the yellow write unit. It may have gone bad in which case it needs to be replaced.
SOURCE: When printing in color a yellow line appears on document
A horizontal line U say and U don't have problems in B&W pages.... ( on the length or width af a A4 page?) the yellow line is just a line or parallel lines at the same distance?.
1-st of all try replacing the Y cartidge.
SOURCE: I have a HP Cp3505 that prints fine when you print
try another yellow cartridge,because if u are using generic cartridges from the same vendor,they might be defective.
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
