Without knowing the frequencies, it is hard to diagnose. If you are trying to listen to police, fire, govt freguencies, the transmissions are scrambled or use split multiple frequencies. You will not be able to receive any voice without the key. If channel jumping is used, you will only hear a veryquick burst of audeo if you are lucky enough to be listening to the correct fequency asthe signal travels by onto the next frequency.
wouldn't have thought so, frequencies change quite often so it would not make sense to preset anything, You may have the option to sort them as you want and install your favourites so that you have quick access to them. If the receiver has a blind search facility it should pick up all the fequencies on it's own
I'm trying to program a Realistic Pro. 2009 and every time I hit program then the frequency and push enter it just keeps saying error can any body help me with this problem???
Some times you can put a capacitor across the fuse, This becomes a filter. Ck with Radio shack..or your dealer This very cheap way to find out if theres enter ference on FM Fequency
If you are performing 1-variable statistical calculations, that presupposes you have one set of data only. Technically all you need is ONE LIST where the data is stored (ex. L1) . However if you have some data elements that are repeteated, you may choose to create a second list where you enter r the frequency (L2 or other). Both lists must have the same dimension (length). When you bring up the 1-var calculation menu , the list of data elements is specified on one line (Xlist) and the fequency List is specified on the menu line Frequency. Thus there is no need to enter two lists on the Xlist line.
You may have a lamp failure, you can remove the lamp probably located on side of tv, check your owners manual for location. With Sony the fequency of blinks can indicate the problem area. Potential of a fan failure if the lamp looks good.
The unit has detected a video signal but can not decode it. It is likely that either the sending signal resolution is too high or too low. Try changing the video resolution to a different level and try again. If no signal appears to work, then the input card is defective.
Sorry I hadnt repied,have been away. Once you have found that the vid plays ok on a certain channel,press stop on vid,so noyhings playing,then there must be a scan or search button on remote,its important you are on the channel that the vid plays on ,when doing it....I looked for a manual bet couldnt find one,
