It won't download on my windows 7 computer
SOURCE: MP-556 MP3/WMA PLAYER
http://www.lenoxx.com/2005/mp3player/mp556.htm if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working.
SOURCE: cant transfer limewire music from my computer to my mp3
The Limewire music is located in your My Computer> C:>Documents & Settings Folder>Administrators Documents (your name)>Shared Folder. You can manually drag these files from this folder onto your device, located under My Computer>Device Name (there may or may not be a music folder, you should put it in there if there is). Once you drag & drop the files, you should safely disconnect your device, then you are done. Best of Luck.
SOURCE: How to download songs to the MP3 player
You cannot use the iTunes service to add the songs directly, because iTunes will only accept brand name iPods within the software itself.
You will need to use Windows Media Player to transfer the songs to your iLo player. All of the info about transferring songs in Windows Media Player can be found in the help files for Windows Media Player, but if you insist I will cut/paste/summarize the directions here for your perusal.
SOURCE: I need help downloading an audio book into MP3 playeer
You have to double-click My Computer, double-click icon of mp3 player, and go to e-Book folder - drag audiobook files into this folder
SOURCE: Can't see downloaded music files on Craig 2GB Digital MP3 player
Going by what instructions say can be a real headache huh... here's a way around all that too legit stuff... your craig should show up in my computer as a removable disk... right click on it and go to explore to view all the thing on the player... now minimize the window for the time being.... if you rip your CDs correctly and play in windows media player.. then they should be listed under-- My Documents/My music.... keep that window open for the time being and find the music you want on your player... go back to the window of the removable disk and find where all your music is stored in it.... now with these two windows side by side... drag and drop the music in your music folder into your Craig (removable disk) folder... you should see a window open saying copying with an ETA.... after your done putting your music in check and see if everything worked out okay... and if ya need anymore help don't hesistate to ask... good lick////peace
