Hello, I need a service center for VTech cardless phone in bangalore. I am trying to contact but i could not get any address nor contact number for the same. Kindly help me in providing the address or contact phone number for service centre. Br, Santhosh Bysani.
SOURCE: vtech 9127, display bad
my vtech 5.8 GHz disconnects while I am talking~replaced batteries and charges the phones for 24 hours. I cold talk 10 minutes during this time 4x I could hear the other person~they could not hear me and then disconnect.
Characters and numbers are choppy too
Thank you
SOURCE: Phones stopped working. They only read
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
SOURCE: need to program phone numbers
Hi!! Follow the link and you can download the manual. Hope this helps!!
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=314056
Testimonial: "Thank you very much for the prompt response, Greatly appreciated"
