SOURCE: Battery Charging Problem
First of all I would make sure that the battery is in correctly. There should be an arrow on the battery that should line up with a plus sign on the battery door. Once the battery is installed correctly then place the camera on the charger and the light should be a solid red. If that still doesn't work then I would be more inclined to think that you may have a defective charger. I would call Casio repairs and see what they can do to help you.
SOURCE: HP photosmart R707 camera does not turn on and charge
I Recomend you to charge your camera before it reaches the lowest level of charge displayed in the LCD Screen This might help the camera to turn on again after long usage but this is something you must take in consideration before it gets ruin but if it is already ruined and you have good luck you might be able to turn it on again and then you shall follow my advise.
SOURCE: CASIO EXILIM EX-Z70 BATTERY CHARGER IS FLASHING RED AND NOT CHARGING THE BATTERY
it wud flash red until it gets fully loaded..its normal...try charging for 90 mintutes..as that is when it is completely charged
Happy to help
HAve a nice day!
tc
SOURCE: Charging...Red Light
This happened to me. The cause was the battery did not fit into the case, This led to poor connection of the battery. After I fixed the loose battery , it worked perfectly till today.
SOURCE: kodak easyshare cw330 new memory card reads full....
Camera doesn't support more than 1GB memory card, so better use less than 1gb SD card
..........Prashant
