Electrical Supplies Logo
d
david lindow Posted on Aug 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No 110 voltage
Model #7nhmfa26105c
Lawrence Oravetz
Level 3:
  • Master 10,558 Answers
  • Posted on Aug 11, 2016
Lawrence Oravetz
Master
Level 3:
Answers
10558
Questions
Helped
2694515
Points
29284
Check the circuit breakers for a tripped one. If all OK, then the brushes may need to be replaced. Here's a tip on how to flash the field in the generator: This tip comes from the Briggs & Stratton Customer Education Department. As an alternative to flashing a rotor winding with a battery applied to the brushes, an electric drill may be used. Follow these steps to flash the generator:
  • Plug the electric drill into the generator receptacle. (Cordless drills do not work)
  • If the drill is reversible, move the direction switch to the forward position.
  • Start the generator
  • While depressing the trigger on the drill, spin the drill chuck in reverse direction. This will excite the field and the generator will now produce electricity. If spinning the chuck one direction does not work, try spinning the chuck in the other direction as you may have the reverse switch positioned backwards.
Use caution not to get your hand or other materials caught in the chuck. As soon as the field is excited, the generator will produce power and the drill will turn on.
The reason this works is because the electric motor in the drill will act as a small generator when spun backwards. The magnets in the drill's motor induce a voltage into the motor windings, which is fed back through the trigger, cord and into the generators receptacle. From there it goes into the power winding of the stator. The voltage going through the power winding creates a magnetic field, which is intensified due to the iron core of the stator laminations. The rotor intersects this magnetic field as it is spun past the power winding, thus inducing a voltage in the rotor winding. Once current flow is present in the rotor winding the rotor has been flashed.
If flashing the field does not make the generator work, you may have additional problems, besides a lack of magnetism in the rotor. Further testing will be needed. Hopefully, this will give a simple way to field flash your generator if needed
2helpful
2answers
Hisense u7g 240 volts support?
if plug into 220 start saving for a new one you will burn it up
1helpful
2answers
What spect of voltage conventer transfer to convent the Voltage 110 to the 220-240 V printer??
110 volt to 220 power converter 220 volt to 110 voltage ...
www.dvdoverseas.com/voltage_converters.htm
110-220 volt voltage converter power transformer 220 volt voltage converters 240 ...run on 120 volt 60 cycles (60hz) and most of the worlds run on 220/240 volt ...
I bought a colliodal silver machine and plugged it in, the voltage was wrong, it's American and it's voltage is 110 and it just stopped working. Have a broken it
Does this Silver sewing machine have a model number?
If you plugged a 110-vold machine into a higher voltage, you popped something. Hopefully there is is an internal fuse. If this is one of the newer electronic machines that has a computer inside, anything could be damaged.
Wire 110 to 220
If you have a 110 volt appliance, all switches , wiring and components are made especially to handle that voltage. If you feed 220 to 240 volts into it, most certainly the machine will be unsafe and likely fail in a very short time. Purchase a step down transformer to reduce your supply voltage to 110. Most good electrical parts stores should be able to supply this.
6helpful
2answers
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
I bought a GE microwave oven model wes1450dm1bb at the USA, but now I am in a different conutry that uses 220 volts as standard. I just read the user manual and in any place says the voltage of the...
No, You'll burn up the appliance. When I was in Germany there were commercially available transformers to step the current down. The transformers plug into the 220 sockets and provide several 110 sockets to plug your appliance into. We purchased several transformers and ran our 110 tvs, kitchen appliances and other 110 appliances. The 220 sockets in Germany were different than 110 and 110 plugs sould not fit.
Feb 23, 2011 • Ovens
2answers
Hello i have a Sony Vaio PCW-W2 that i brought to canada from uk. how do i switch voltage to 110?
u can find voltage converter connectors......try using that....u can ask for travel adapters....hope u find them
This tv has 110-245v do i need a converter to make it turn on toshiba model # 329p8m
that tv has minimum-110 to 245 max, the power supply shoud be switched mode. there for any voltage from 110-245 it can work without problems.
check if your voltage is above 245v, buy a transformer of 110 output, to be on the safe place on your tv.
but if the voltage is within, no need to modify.
okey
2answers
Low voltage only or can timer be used for 110 v
1 hp= 750 watts
125 vac = 125 volts alternating current, wall outlets
5 amp= 5amps
125vac x 5amps= 625 watts
a timer is a switch with a clock on it. just like a switch in a lamp cord.
Top Electrical Supplies Experts
john h
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
