SOURCE: My Canon MP495 Pixma printer
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
SOURCE: error 5200 or P08 on
The error indicates the following : Head overheating error.
Yes it is most likely the print head itself or at worst the logic board.
Replace head/logic board is the only answer.
SOURCE: Canon PIXMA MP495 InkJet Printer - Offline issues
For Vista wireless setup: Open your Control Panel. Choose Printers. In the Printers box it lists your printers. Hover over the wireless printer icon, right click, choose Run as Administrator, then choose Use Printer online. This should change the status of the printer to Ready (from Offline). Be sure you've chosen this printer as your default printer. Might have to do this on a regular basis.
SOURCE: What does Error code P03 mean on Canon Pixma MP495
Download the manuel from this link below:http://www.manualowl.com/p/Canon/PIXMA-MP495/Manual/68096
It might have some trouble info for you. ;-)
