SOURCE: IR 5570 Error code
Subject:E840 Indicated in response to damage on the Fixing Roller Trust StopDetails:<Problem>Damage to the Fixing Roller Thrust Stop leads to the indication of error code E840. At times, it can also indicatecode E001/E004.<Cause>The strength of the Fixing Roller Thrust Stop [1] is not adequate and over time, it tends to show damage, failingto prevent the Fixing Roller from moving to and from. Or, the damaged stop can fall to the Shutter DriveAssembly to cause the shutter to malfunction, also resulting in an error.
<Factory Measure>Modify the method used to shape the fixing roller thrust stop to increase its durability.
Servicing Work:If any of the foregoing symptoms is noted, or in the course of a service visit, replace the existing Fixing RollerThrust Stop with its new type.
SOURCE: how to remove this error e000840-0001 in ir 6570
bagaimana caranya perbaiki kade 000840-0001
SOURCE: Error code E000840-0001incanon ir 6055
My machine canon ir6055 display error E000840-0001 and E00060-0001 i am all so cheek the machine fuser unit last time automatic open the lock fuser i am set the fuser agin problem
and E000013-0001
