Motorola Mobility H19txt Universal Bluetooth Headset Logo
J
Jim Alt Posted on Aug 08, 2016
After months of working fine with my iPhone 5S, I'm now getting continuous fast beeps when I connect my H19txt. Restoring to factory setting doesn't cure the problem.
Reset to factory settings iphone 6
You can resort to iTunes to restore iPhone to factory settings. Just follow below steps to do that.
Restoring iPhone to Factory Settings with iTunes
iTunes enables users to back up data to iTunes and restore iPhone to factory settings. Before you start restoring iPhone to factory settings, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, the detailed restoring steps are as follows.
1. Plug iPhone into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPhone at the upper right corner of iTunes, and then the information of your iPhone will be shown. Click the "Restore iPhone" button in the window to start.
3. iTunes will ask whether you want to back up iPhone before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPhone. Then iTunes will start restoring your iPhone to factory settings.
3. Click Restore again to confirm. Then iTunes erases your iPhone and installs the latest iOS or iPod software. After you restore your iPhone to factory settings, it will restart. Now you can set it up as new.
For more methods, check: How Do I Restore My iPhone to Factory Settings
I have a iphone 7 s plus and im locked out of it and i try to restore and download it to my laptop but when its close to being done it crashes i need help.
If you tend to restore iPhone to factory settings, there are two methods for you.
If this solution won't work, follow this post. How Do I Restore My iPhone to Factory Settings
I need to change my password but my 5s isnt allowing me to do so
Go to iphone setting - then passcode or touch id & passcode. now tap on change passcode and then enter your old passcode and then new passcode. And if you forgot your passcode and your ipod iphone disabled and you want to unlock disabled iphone ipad.
here is the detail procedure
First method you can restore your ipod. But this will erase all your data on ipod. So if you have recent backup then go for restoring ipod. For that just connect your ipod to computer- then open itunes. Make sure you have installed latest itune version otherwise update your itunes first. Now open itunes then find your ipod under deivce tab at the top left sidecorner. Click on your ipod icon. Click on summary and then click on restore.
You can also restore your ipod from old backup also. For that open itunesfind your ipod under device menu. Now select your ipod and then right click on your ipod the you will get options for restore from backup.Select restore from backup this will provide list of all your previous backup on that computer itunes. Now select your backup which you want to restore and then click on continue. Once your restoring is completed your ipod will shut down and then again restart your ipod it will take few minutes to start up. And it also asks few information about you. Once you complete all that procedure your ipod is unlocked which was disable or locked due to wrong passcode.
How to factory reset iphone 4 withouw icloud password?
It's quite easy. You can resort to iTunes to reach this aim. Just follow below steps.
iTunes enables you to restore iPhone 6 Plus to factory settings. Before you start restoring iPhone to factory settings, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPhone 6 Plus with iTunes as follows.
1. Plug iPhone 6 Plus into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPhone 6 Plus at the upper right corner of iTunes, and then the information of your iPhone 6 Plus will be shown. Click the "Restore iPhone" button in the window to start.
3. iTunes will ask whether you want to back up iPhone 6 Plus before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPhone 6 Plus. Then iTunes will start restoring your iPhone 6 Plus to factory settings.
3. Click Restore again to confirm. Then iTunes erases your iPhone 6 Plus and installs the latest iOS software. After you restore your iPhone 6 Plus to factory settings, it will restart. Now you can set it up as new.
For more methods, check: How to Restore iPhone 6 Plus to Factory Settings
My Smart satarter doesn't work because I upgraded the iPhone 5s to iPhone 6 plus. I redoenloaded the viper app but it doesn't work?
There can be problems when iOS is upgraded. Get the latest version with the latest bug fixes. Watch the Viper app for version changes and download it when it gets updated. Check the Viper support web site:
http://www.viper.com/Support/
Have yahoo email and IM on iPhone ; Tried to install same on IPad . Could not get IM on iPad ; but trying to get application messed up the connection on my IPhone . Now the iPhone app is not working. ...
I prefer Aunsoft iMedia Converter for Mac to help me convert MXF to ProRes for iPhone 6/5S.
I had used it for 1 year to convert MXF to iPhone 5S, and I plan to continue to use it to convert MXF to iPhone 6.
2answers
Iphone 5s battery life
My iPhone 5s 64GB battery life is not much better than my 4s 64GB battery life, but considering that the 5s is much much faster than my 4s I guess that's pretty impressive.
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
