It worked fine then next use could not get any power. Thought it was plug but tested with another item that worked fine
There is a fuse that you can check. There is a possibility that it is the ignitor, the auger motor, the controller, or the fan.
The process to tell which item is bad, is to disconnect all but the power and the RTD wire, plug it in and turn it to smoke, If the fuse blows it is the controller, if not turn it off and start hooking up the other wires one at a time, When you find the one that fries the fuse, you know what is bad.
