Brakes don't work - pedal goes to the floor. Where do I check the brake fluid and what oil goes in there?
I am going to have to guess you are referring to a 580 C Case backhoe.
In any case never ever put anything in a brake fluid reservoir but brake fluid, and the right fluid to be sure, or you will seriously damage or destroy the brakes "forever".
The brake fluid reservoir is usually plastic, and often you can see through it just enough to see the level of brake fluid.
It should be located near the front of the brake pedal, and is usually sort of white in color, with a black cap that can be screwed off.
God bless your efforts.
