Passport 8500 X50 Radar Detector Logo
Posted on Nov 19, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How does one get your detector recalibrated? Mine suddenly lost sensitivity
It works, sorta but doesnt go off as strong and loud as it used to
Anonymous
Level 2:
  • Expert 134 Answers
  • Posted on Mar 17, 2009
Anonymous
Expert
Level 2:
Answers
134
Questions
0
Helped
85383
Points
330
Only Bel/Escort has the expertise and instrumentation to recalibrate your radar detector. They automatically do other things whenever you send in a RD for service. For example, aside from diagnosing and repairing any issues (I think that your RD's antenna needs to be replaced or repaired), they also recalibrate it, fully test it, and update its internal computer firmware to whatever the most recent firmware is. In short, when your RD comes back, it performs just like a brand new RD.
1helpful
2answers
Metal detector 3110 ll stop detecting any small metals and is 15 days old, what can be the problem? Is like it lost 99% of the sensitivity in 2 weeks, with new Alkaline Batt,& I been very careful!
metal detectors are ******* batteries especially alkaline type so check the charge in the batteries with a voltmeter
if they are still at correct voltage , take it back for a warranty check or replacement
Laser alert constantly goes off
Laser is very sensitive to false alarms often set off when driving by an airport, or military base. Set your laser on City Mode and pay attention exactly where it goes off. Mine goes off constantly in the same place which is a air force base in Tucson, AZ. Unless you drive like crazy shut it off in the city although the cops like to use a hand held one in school zones. In 6 years of driving in Arizona I have had one real laser alert, and other than false alerts, real ones are far and few in between. Check when and where the unit alerts and use different sensitivity settings. One more thing, if your laser warning goes off you already have the ticket since the cops use them at close range unlike the radar bands. Hope this helps.
How to fix loud key on Privia PX-830
I just fixed mine, it was making the loud sounds and had seemed to have lost the sensitivity. Take out all the screws on the outside, then the sides can come off. That gives access to the inside where you can take out a few more screws (easily seen) and open it all up. The keys themselves just snap in, so two small screwdrivers or strong fingernails can pop them back out. Clean the rubber contacts (they look like little sockets) with Q-tips and rubbing alcohol, then replace the keys. If you take out the white keys of an octave first, then the black keys (keeping them in order) it is a lot easier.
1helpful
Sidewinder Precision Racing Wheel sensitivity difference
The potenometer in the device is worn. This is a variable resistor device use to variate the difference between turning right or left. I don't know if you can obtain parts for this item. May consider buying another one.
2answers
When i plug in my rx 65 it says service required
it's stolen, or doesn't recognize the POWER supply.
1helpful
Stereo stopped working along with speedometer
It's probably not a fuse. It sounds like your vehicle speed sensor went bad in the transmission. The reason your radio stopped working was because your radio is probably equipped with speed sensitive volume and it requires a speed signal to work.
Passport 8500 will no longer switch to LOUD mode
Try doing a factory reset as described in the user manual since it is possible that a power fluctuation has somewhat corrupted the internally saved user settings.
PHYSICS
This is the invisible to the eye sorta "Cloud" of energy surrounding a conducting medium..
Whenever electricity "Flows" thru a "Conductor" a little of it sorta "Seeps out" thru the "Walls" and sorta "Lays" on the surface in a sorta "Layer" the higher the Voltage/Current the "Thicker" this layer is.
This energy can be picked up and measured with various types of "Detectors"..
I believe the Field is measured in "Webbers"
1helpful
2answers
My psp makes a wierd grinding sound when loading umd's!
mine makes a medim-loud nosie and always have done, it doesnt affect my gameplay, nor should it stop you turning it off.
4answers
Beltronics pro rx65
false laser alerts when sun is low..
Top Escort Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
