Black and Decker USA Black & Decker MM1800 18" 12 amp Corded Electric Lawn Mower Logo
Ron Truxton Posted on Aug 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black and decker electric mower hums but blade does not turn. appears the brake is not releasing for the blade.
Everytime it hums the blade is locked in the forward direction and never spins.
richie46
Level 3:
Top Expert:
  • Black and De... Master 12,962 Answers
  • Posted on Aug 02, 2016
richie46
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2945291
Points
58151
Something has the motor unable to turn. Do not turn on till you locate the source of the problem lest you burn it out.
How to remove motor cover Black & Decker lawn mower EMAX32
Before you start removing covers and panels unplug the mower. Turn the mower over and carefully try to spin the blade by hand. Your checking to where the issue is most likely to be.
Does the motor sound different when you pull the Start trigger? If it sounds a lot faster than normal, it could be an issue between the motor and gearbox.
Does the blade spin really easily and feel like it's not bolted down? Does the blade not turn at all like it's 'locked' or 'jammed'?
- A loose or floppy blade is commonly the centre mount bolt for the blade is loose or the blade isn't seated correctly.
- A 'locked' blade could be a gearbox or a motor issue.
1helpful
How do you change a blade on a black and decker Rota-twin GR101 mower
my search shows that up as a
black and decker /flymo electric mower type
no picture on the parts list
of the rotating part being metal
two types of blade sets ...says its plastic and just clips on
is that for real ....plastic clip on mower blades
will this work
pull to the larger slot to release the old blade and back to the smaller slot to hold the new blade in place
1helpful
I can't get my blades to start rotating
check to make sure your blade brake is releasing all the way
Cannot tighten blad for 18" Electric B&D Mulching Mower
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
3helpful
Electric mower will not work
the shear pin has broke on the drive shaft put a new one in.
Black & Decker MM875 blade
You can pick up a blade at almost any hardware store.
Replacing Black and Decker 18" lawn mower blade
Black and decker has a web page and 800 number which I can't locate rigth now
B & D mulcher mower stop while mowing
electric & battery operation mower are not suppose to be use when grass are too long & wet, it draws lot of power that appear to runs slow.when you see try to restart i think the brake is trying to kick in.
Top Black and Decker USA Garden Experts
Jay Finke
Jay Finke
john h
Are you a Black and Decker USA Garden Expert? Answer questions, earn points and help others
