Green light on tv turns on buts screen does not turn on, I have unplugged it for a period of 1 hr. still nothing, could there be a fuse or something gone?
FIRST GREEN LIGHT WOULD COME ON. TOOK IT AWHILE BUT ITWOULD FINALLY TURN ON...NO NOTHING. IT'S GETTING SPARK CAUSE WHEN I PLUG AND UNPLUG IT AT THE SOURCE OF ENERGY IT SPARKS. FUSE IS NOT BLOWN
Hi
First get ahold of Dish Network and have your dish realigned. Sometimes excessive wind or birds can move the dish away from it's optimum recption. At this point also, the repair person can tell you if the equipment is bad.
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the
fuses that protect the Convergence IC or IC’s is blown---set will detect no
voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO
GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Unless you know Solid State Electronics, there is nothing you can do. At best, You could unplug the TV, remove the back cover, slide out the Circuit board, and check the fuses. They will be at the front of the Circuit board, left hand side. But in all likelihood, it is not just the fuses, the Power Regulator STR would also be short circuited (happens often in SONY TVs) and so it is best that a professional technician have a look.
