Garden Logo
R
Robert E Smith Posted on Jul 30, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Part # for spark plug wire on stihl saw model ms 180 c
Part # for spark plug wire on stihl chainsaw model #ms 180 c
Bill Boyd
Level 3:
Top Expert:
  • Stihl Master 53,816 Answers
  • Posted on Jul 31, 2016
Bill Boyd
Stihl Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11936079
Points
172802
Spark plug wires on small engines are normally part of the coil so you may have to get a new coil pack
talk with stihl service parts or service shop
1helpful
Need part # for spark plug wire on Stihl chainsaw model ms 180 c
Robert, NGK BPMR 7A or BOSH WSR 6F , (gaped at .020"/ .5 mm) are what is recommended in your manual pg. 52., Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.stihlusa.com/WebContent/CMSFileLibrary/InstructionManuals/STIHL-MS-170-180-Owners-Instruction-Manual.pdf
Spark plug cross reference
NGK 4626 BPMR7A Standard Spark Plug Pack of 1
NGK BPMR7A Yard Garden Outdoor Living eBay
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
How do you remove the clutch on a 025?
remove spark plug.
block ther piston with a piston stop.
remove clutch drum exposing the clutch
it has to be turned clockwise to remove it. 19m socket
Replace pull cord on Stihl MS 180 C chainsaw
Are you asking something, or telling someone to replace a pullcord on a chainsaw?
Stihl 025 starts but cuts out have replaced spark plug and new carb
check the spark arrester screen in the muffler. if they stop up it will run like it has
no power and will stall
2helpful
Stihl 025 chainsaw wiring - two wires go into the the handle assembly - Green/Yellow and Grey - they fit onto spade connectors but cannot figure out which nand where?
the wires go to the kill switch it does not matter which wire goes where.
one wire goes to the igniton module.the other goes to ground
Can not start the ms180 chain saw, tried new plug, new gas, starting fluid etc. suggestions ran this morning, and now will not start. only been used twice
Remove the plug and then plug into plug wire. With the spark plug laying on top of engine pull the recoil a couple times and you should see spark at the plug. If all is good and there is the proper mixture of gas/oil ratio in saw then >>With trigger depressed fully and choke on, pull until it fires and then shove the choke in. /////If no spark and the saw is new, I would return to retailer.
1helpful
How to start stihl ms 180 c
pull choke full on pump petrol 5 to10 times it should try to start take throtle of full to next button and try again
16helpful
6answers
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
