Cooktops Logo
R
Roger Posted on Jul 30, 2016
Kitchenaid kfgu766vss01 cooktop locked out--all lights flash and unit beeps every five seconds
Cooktop locked out--all lights flash and unit beeps
  • Roger
    Roger Jul 30, 2016
    Top is stainless and knobs come though control panel which is glued to the top. Gas with elecronic ignition
1 Related Answer
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Nov 09, 2008
SOURCE: Kitchenaid Gas Cooktop with electronic ignition
you sound as if the short is occourring within the switch assy perhaps water has spilled on it, listed on gas range, but assuming you have an electric unit, with the knobs poking through the glass
The red padlock icon that usually unlocks with the 5 second touch of a finger won't unlock the cooktop.
Have you tried disconnecting the whole cooktop from the main supply for about 5 minutes? Sometimes when reconnected the fault goes away.
Nov 28, 2015 • Cooktops
Hello, i cannot turn the child lock off on my stovetop. this is a brand new problem as i do know how to normally turn the lock off.
Not sure if this is for your exact model but here is a link to an Online User's Manual for one similar:
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KECC508RPS_Use%20and%20Care_EN.pdf
Just click on the link (underlined and highlighted text) with your mouse and a new browser window will automatically open to show you the information in the manual.
On page 7, it reads as follows:
To Lock Cooktop: Touch and hold the CONTROL LOCK/
ALL OFF keypad for 5 seconds. After 5 seconds, CONTROL
LOCK will glow red, indicating that the cooktop touch controls
are in the lockout position.
To Unlock Cooktop: Touch and hold the CONTROL LOCK/
If you have any questions or require further assistance just comment back to this page and I will endeavour to help.
Good luck and please click on the 4 Thumbs Up rating icon if this was at all helpful.
Thank you very much.
Joe.
Can't turn on KECC508 cooktop I didn't buy it and it is in the house and the light in the middle to power all burners off is lit.
The middle light is the lock. You must hold it down for at least 7 seconds to unlock it, then the middle light will go off. Your hands can't be wet, or none of the buttons on mine work right.
5helpful
I can't turn on the range. it has a light that says all off control lock
From the manual, page 7:
10helpful
2answers
Stove top in lock mode
Hold your finger or thumb on the red light for a few seconds, and you will hear three beeps. This tells you that the lock is off. If the light is not on, do the same and there will be three beeps, and the light will come on, telling you that the lock is back on.
13helpful
4answers
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
HOT SURFACE LIGHTS
Hold the button down 5-6 seconds and it will go off...then to cut on...press down again for 5-6 seconds and it will come back on.
Top KitchenAid Cooktops Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
