Does anybody have any tips on replacing the gear wheel that turns the coloured cylinders on a Wurlitzer OMT cd? I assume the cylinder needs to be removed to get to the gear wheel but how is this achieved? Seems to be various plates with screws but screws not easily accessible. Thanks for any help.
SOURCE: Wurlitzer omt
If it shows just 8 in the LED display then it is caused by the amplifier being distorted (set too loud) and/or fuse Si3 on the amplifier panel requiring changing.
SOURCE: Wurlizer OMT tilte page malfunction
as i think inside ur jukebox there will be one bus in white colour which is connected to another end by this only the player will be able to read the format s like mp3,mpg and others so this bus may be not connected there try opening and checking it out... if u r afraid of opening then just visit the technician he will do the same....
SOURCE: I need to find a place to buy replacement parts
If your jukebox is ineed a Wurlitzer then you can order parts via a dealer, if the jukebox is by another manufacture then I suggest you look on the two following websites:-
www.victoryglass.com & www.happ.com for used parts www.jukeboxparts.com or in the UK at www.jukeboxparts.co.uk
Regards
Alan Hood
ami-man
UK
SOURCE: Wurlitzer 1015 OMT Disc spins, then stops....
fault could be fuse in cd transformer or decoder board worst it could be the laser unit
