SOURCE: TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
SOURCE: PV 1500 Amplifier
The final out put amp stage is out. MOSFET transistors likely. Hope this is helpful.
SOURCE: i need a solution to repair peavey pv 2000 power amplifier.
Your best bet is to request a service manual from Peavey itself. These are usually available for around $20 or so. Call Peavey and ask for the service parts department and make your request there. They are very helpful and should be able to assist you.
Dan
SOURCE: i have Peavey Pv 2600
One side of the amp has failed and repair is NOT DIY. Take it in for servicing. This amp has many components in the power amp and repair is complicated. A failure can lead to 20 components being damaged. Failure to replace all damaged ones can result in immediate failure destroying the replaced ones.
