Turntable manual for sony hk114 turntable
Turntable appears to be seized up
Zenith is4041 record/ cassette player
There is a clip in the center of the turntable's spindle. Remove it and the turntable platter should lift up. That model of turntable is driven by a rubber surfaced idler wheel that is tightly held between the motor shaft and the inside of the turntable's rim by a spring.
Most likely problem(s):
1. The motor is seized. (Even a seized motor will hum, from the 60Hz vibration of its windings.) You should be able to spin it freely between your thumb and index finger, with no resistance. If not, you must totally disassemble it (easy job), clean out the bearing journals with alcohol, lubricate, and reassemble. If you decide just to oil it without cleaning out the bearings, it will quickly seize again.
2. The idler wheel is seized on its shaft. Same solution as 1.
3. The rubber surface of the idler wheel has become hard with age. Best solution for this is to replace it, if you can find one. Alternatively, there are various liquid chemicals around that can renew the surface of the rubber.
4. The pivot mechanism that allows the wheel to assume its proper position is seized. Same solution.
5. Any combination of the above, including all of them! :-)
While you're in there, look at the geared wheel that engages the teeth on the inside center of the turntable's platter. It will have a little "kicker" mechanism that is moved by the turntable's tone arm (part that holds the cartridge) as the tone arm nears the end of the record. This little mechanism is notorious for seizing, and should also be cleaned out and lubricated.
Cheers!
Sony PS-LX250H is running slow from time to time notibly when playing slower songs like John Denver 33 albums.
Replace belt of turntable to fix speed issue. Part number is as follows:
421549201... BELT
Available in Sony Part Store for $10.31
Download user manual copy from Sony Support as belt replacement procedure is written in manual.
Thanks.
Sony PS-LX350H turntable Phono cartridge looks not vertical, tilt to the right and non adjustable, this is normal?
Did you inherit this machine this way or did this problem just appear out of nowhere?
Refer to the manual, available at retrevo.com for free after you register (keyword = Sony PS-LX350H).
Page 8 shows how the cartridge attaches to the headshell.
Sony PS-LX250H Turntable Problem
If Sony does not have it available, you won't be able to find one. You can go generic, but you have to worry about size and fit.
- OPTiC
Turntable Technician
www.1200s.com
Turntable ps-x55 / arm want move stay in lock mode
I have the exact same problem with my TT - a PS-X55. It appears that the motor has failed. Too bad, as I was told the replacement motor part is no longer stocked by Sony. For what it's worth - the part number is 154116500.
Let me know if you manage to find some who has the exact part stocked.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
