Cell Phones Logo
Fatih tademir Posted on Jul 24, 2016
Files, apps some corrupted automatically phone inside. cause?
Files, apps some corrupted howdy, phone mine 4-5 day closed stayed. however this during inside some items damaged & wiped. voices, images, applications solution?
5 Related Answers
blackutak
  • 16 Answers
  • Posted on Aug 11, 2009
SOURCE: text message failure, error message
reset that phone
keys; 3845#*610#
try this
Anonymous
  • 590 Answers
  • Posted on Aug 25, 2009
SOURCE: app problem in sony f305
Sony Ericsson F305 supprots only Java softwares. Download the java apllications which you need from www.getjar.com after selecting your particular mobile model. The extension of the application should be ".Jar" Then transfer this jar file to your mobile and try installing it. The installation files transfered from other mobiles using bluetooth may not be compactible with your mobile. If your problem still exist, then activate the GRPS, go to wap.getjar.com and try downloading the application directly to your mobile. This should work fine. I hope this is helpful to you.
Anonymous
  • 1871 Answers
  • Posted on Jan 09, 2010
SOURCE: Automatically getting on to Loudspeaker NOKIA N70:
update your phone's software !
Anonymous
  • 308 Answers
  • Posted on Apr 17, 2010
SOURCE: dump file created application closed
sounds like corrupt software, try sony ericsson update service which is on sony ericsson webiste
Anonymous
  • Posted on Dec 22, 2010
SOURCE: My phone Nokia 5235 is
delete the extra files of the areas which cover major portions of the memory
Why do my blu phone gets overheated when i play games especially
Hi Cherisse,it's a common feature to most modern day smartphones;with high end specifications and capabilities.Nothing to worry about.The model is on Android just like mine.An easy quick fix would be to download a phone cooling app.Visit google play store.Download "Battery monitor" which will automatically warn you of the phone's temperature,then work for you on what is causing the hot feeling plus stopping it for you.
tip
Save battery power by turning off your apps..
I`ve discovered that my I-Phone`s battery power kept running down really fast, the problem is that all the apps that you use thru-out the day stay open and drain power from the phone. I found out I had like 40 open at once!!
to tun them off.. get to you apps page and double click round button at bottom of phone. you will get a row of 4 apps at the bottom of the screen. hold down one of the apps, and they will start shaking. just click on the "-" minus sign and begin to close them all out. it does not delete the app, just closes it. welcome to more battery life!!!
on Nov 16, 2011 • iPhone Apps
Why can't I update an application?
often you are unable to update an application due to your device running an older version of iOS, try seeing if an update is available for iOS so you can update your favored app. Secondly in some cases you simply mightn't have enough storage space to download the wanted update, try removing some pictures or videos from your device. If both these scenarios do not apply to you and/or a grey icon is showing where an app is updating the file may be corrupt an in this case you will need to restore your device (after backing it up in iTunes) and then recovering your backup, (all this will happen automatically once you choose to restore your device in iTunes) this will also remove any other corrupted data/unnecessary files.
Wen i start any app d msg of memory full appear me & app close automatic.
Good day. Its the common problem for nokia N73, try to delete any files from your phone memory. Its one of the reason why your phone got hang-up, remember do not use your phone memory for saving large files, but instead always use the memory card, to avoid this problem. Or reformat the phone if necessary. thanks
2helpful
2answers
Nokia3110c phone operating system download and install
hello!!!
plz guide me, my nokia3110c, has a problem with inbox opning.
on opening of inbox nokia phone is resarted.
there is 1kb file remained in inbox after deleting all the inbox massages.
plz help......Thanx....!!!!
Hi, My Nokia N70 which i am using since last three years is not functioning properly since last one week. When some call comes, sometime it rejects automatically. Sometimes when i receive a call,...
It willbe ideal to have the phone cleaned up specially if you notice any moisture on the mother board/front panel. use a heater to warm up the board, clean with a brush and reset the phone back. It is also possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. the possibility of errors in the hardware cannot be ruled out. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
16helpful
6answers
6helpful
Music in music library shows corrupted cannot delete
Connect ur phone to ur PC in Data transfer mode.
Make sure u can view hidden files in ur pc.
Open E:\private\
where E: is ur memory card drive name
Delete all the files in "private" folder.(u can copy and save all the files before deleting incase anything goes
Disconnect ur phone and restart it.
Open music library it will refresh itself automatically.
Mines working fine now....
2answers
My pearl 8120 automatically deletes messages and call logs on my phone
Mine was doing the same thing. I called ATT and was told to remove and reinstall the battery and the sim card making sure the sim was in tightly. once i done this it hasn't happened again
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
