SOURCE: no disc
check ur cd/dvd into other drive if it reads properly then there is the problem dvd player, try cleaning the lens
if it does not work take to service center
SOURCE: I bought a Sylvania DVD player and no new disc
Have you tried to unplug and plug in the Device after few
minutes, say 30 minutes?If not, try it.
It is quite a common
problem with this model, you can try a clean on the lens,you can use a
DVD cleaning kit which you can buy from Radio Shack or similar or you
can clean manually.
To clean manually unplug from wall and leave
two minutes.Remove cover identify the lens as a small round glass lens
in the DVD tray assembly.Clean with the glass lens with a cotton bud or
similar, use a small amount of isopropyl alcohol or do the clean dry,
any other cleaning product could damage the unit.Remove any foreign
objects in the unit.Reassemble and test
If no luck then
you will need a new laser assembly I'm afraid.
Now, regarding Caps. Yes, it could be another Problem. When you Open the
Player, you would see Caps like :-
If you see, Cylindrical Type Components, all those are Caps. There might
be chance that any one of these could be Leaked / Bulged / Swelled.
Make sure that there is no Cold Solder Joint and there is no other
Broken Component on the Board.
If you find anything Swelled /
Leaked / Bulged, you could De Solder and Re Solder the New Caps. The
caps could be easily available in the Market. You could buy it Online or
you could go to Radio Shack, Fry's.Make sure to Buy a Similar one. I
have seen , if you buy a Low Quality Cap, it could again Swelled or
Blown.Usually Bad Caps have Ammonia Kind of Odor.
The Cost of
Caps would be less than $20.
I hope that the
above information would be useful for you to Resolve the Problem.
Let
me know,if needed further assistance.
Hope i helped you.
Thanks
for using ' Fixya ' and have a nice day!!
