I have a Haier Air Conditioner window unit that is leaking inside the house. What are some possible causes and solutions?
There are basically 2 causes:
1. The rear of the AC unit is not tilted down enough, so that water in the drip pan flows to the drain hole in the rear of the drip pan. The general rule of thumb for rear downward titl is 1/4" to 1/2".
2. The drain hole in the drip pan, near the rear of the unit is clogged. Locating the clogged hole can be a challenge, as the clog will blend in with the drain hole. Patience & persistence are needed in locating it. A pipe cleaner works well to clear the clog from the hole.
Hope this helps you and thanks for choosing FixYa.
