My dryer drct70w will not power up have check on/off switch and fuse they are working ok none of the lights illumiate
Machine does not switch on or the programme does not start. Machine is not activated when set.
* It might have not been plugged in.
* The loading door may be ajar.
* Programme might have not been set or the «Start/Pause/Cancel» button might have not been pressed.
* «Childproof lock» might have been activated.
* The condenser cover on the models with a condenser might not be closed securely.
* Make sure that the machine is plugged in.
* Make sure that the loading door is properly closed.
* Make sure that the programme has been set and it is not in "Pause" mode.
* Deactivate the childproof lock.
* Make sure that the condenser cover and the red lock is closed securely.
A Call an authorised service agent if the problem persists.
Hey Malcom, I'm sorry to hear about the missing rubber ring your dryer. If it's an O-ring then I wouldn't think it would be too hard to replace, although I could be wrong. I'm pretty sure there are all sorts of websites online where you can look for spare parts, maybe try looking for one of them. http://getsparesllc.com/oems.jsp
