Need picture of the system without covers
SOURCE: how do i hook this up Samsung HT-WX70 Theater
1. Connect the front left,
front right, center, and sub woofer speakers to the back of the home theater
system.
2. With
the home theater system off, insert the TX card into the TX Card connection
(WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing
left.
3. Connect the
rear left and the rear right speakers to the back of the SWA-3000.
4. Plug the power cord
of the SWA-3000 into an electrical wall outlet, and then switch the power
switch on the back of the SWA-3000 to [ON]
Hope this helps!
SOURCE: system is samsung HT-TWZ415. all speakers work, not the sub
Check all of your connections, and make sure all cords are firmly connected.
Make sure if the subwoofer has a power switch, it is on, and if not, that it is likely to be faulty.
SOURCE: No sound from a Samsung HT-Q40?
It's part of an HTiB (Home Theater in a Box). Get the speakers that it's designed to mate with. HTIB's are not like components. Due to proprietary connectors and who knows what else under the hood, they are not intended to be mixed and matched with other units.
This unit has standard speaker connections so you might be able to find some speakers to hook up to it, but its original speakers were rated at 3-ohms impedance and the spec for the amp is also at 3-ohms. You probably won't blow anything up trying them, but don't expect earth-shattering volume from typical 8-ohm speakers. As the saying goes, individual results will vary.
How exactly did you expect the TV to be the speakers for this thing? It doesn't have an outbound audio connection. TV's are traditionally the part that makes pretty moving pictures while other electronics and speakers take care of the audio end.
If you need the manual, go to retrevo.com, register, find it using >>> Samsung HT-Q40 <<< and download it for free.
SOURCE: Samsung home theatre system HT-TZ422 - rear speakers don't work
I bought the system samsung HT-TZ 422 but wireless receiver module is not connected spikers or not riding tx card.Sound test system is show all spikers but from wireless module is not hiring.When can i get any hepl.
Thanks.
Marek.
SOURCE: The front right speaker channel on my Samsung
Normal 0 This is a common problem on this model. The fault is caused by the PULSUS PS9829B digital audio processor. We ordered it in from a Samsung authorized service centre.
